Multi instance and multi rate range effect request
Would be powerful to be able to run multi instances of effect. could we get multi layers like MA2, or multi instance please.
Would love to be able to run lets say an aqua color mix pulse in one direction and have an amber color mix pulse in opposite direction across the same fixture array. currently if i run the aqua pulse then try to run the amber pulse at the same time, the amber pulse stomps the aqua pulse.
I would like to be able to set a a rate on an effect that runs a set range lets say 1 thru 3 seconds this way the effect will run slower then faster then slower then faster, and the ability to set the rate to random  within a set range, so i can further have the effect slow down and speed up randomly within set range. this action could be controlled by a range rate
This option could be controlled with the following added rate options: Range off, range linear, range random, and a range rate.
