2.9.1 multi console parameter reset.
2.9.1
Setup is a Gio @5 + a nomad in client, both on the same user.  If a light is selected on the Gio, it selects it on the nomad (expected) but when you use the nomad to change a color with the color picker it will at first change, but additional changes will reset the lights back to their original setting.  So specifically this is noticed when using tint controls. Pressing +green once will act as normal, press it again and it reverts back, press it again and it goes one click up.  If I adjust using the color wheel once it will work, touch it again and it goes away.
This is a common setup for me where I'll have a Surface and a laptop running nomad next to my @5. This gives me additional screens but also allows me to work in blind or on magic sheets while programming on the @5.  The Surface while it's in-between other uses usually sits as a large color picker.
Thanks.
