Hi All,
Found a bug in the Magic Sheet system, specifically, in command buttons. Every way and method I try, firing actual recorded Macro's from a command button fails. So far I have tried:
Macro 1
Macro_Button 1
macro: Macro 1
macro: Macro_Button 1
local:/eos/fire/macro/1
All of these fail, usually just displaying "Macro 1" on the command line but not running anything. I also found attempting to run a Macro via the Ad-Hoc macro function results in it attempting to run Macro 0 sometimes (from the diagnostics). For everything else it just displays it in the following manner in Diagnostics:
(L)USER: 1-> Macro 1
This was all from a Ti running 2.9.0 Build 77.
