Hey Guys,
how would y'all write a simple chase in Ion having two lights randomly going from 0-60% (seperately)
and then bring this into a cue?
- corey
Hey Guys,
- corey
Corey,
Hey, that's a pretty good one. I thought it'd be a no brainer till I tried it. I was thinking about doing two seperate chases with random rates (one for each channel), but I couldn't get random rate to work on any effect type. What am I missing?
This was an Ion running 1.4.2.
Also, I wish the LCD Soft keys would populate consistently throughout all of the Effects editing screens.
B
BSmith said:I was thinking about doing two seperate chases with random rates (one for each channel), but I couldn't get random rate to work on any effect type. What am I missing?
With Random Rate, you need to specify a rate value. ie: [random rate 50 > 120 enter]
To answer Corey's question, a step effect with random rate is one way, the other way I can think of would be using linear effect. Clear the sinewave pattern and draw your own random pattern. Set the effect to a grouping of 2. Play around with the trail, and maybe a random rate. Although this isn't truly random, if you draw a kooky enough pattern, it will look random
Cheers
BFJ
