Jason - looking into this now. Will share results of investigation....
a
Jason, looked at your show file. If the Go to Cue action is done on cue list 1 (which has an execute instruction to a secondary cue list), by default, that Go to Cue action will sync all associated cue lists. If you want to go to cue on the main cue list, and not impact associated cue lists, you can [Go to Cue] [0.1] [minus links] [Enter]. A go to cue on associated cue lists (such as Cue list 111 in your show), has no impact on the main cue list.
Does that make sense??
a
Hmm... will do. Is this problem always seen when a go to cue is executed on list 1? Or are you seeing any strangeness when you do a go to cue on list 111?
thanks,
a
