Hello.
On the @5 I know that the way to get to 6-10 on the masterpage is [fader page] + #/ but would it be possible to swap between 1-5 and 6-10 on the same page with only [fader page] +/ witout needing the number before not leaving the page I'm at.
Hello.
[Fader Page] [Next]/[Last] should accomplish this.
FaderPage Next/Last isn't a valid button combo
Interesting...it just worked when I tested it in the offline editor. It’s possible that on a real desk it’s [Fader Page] [Page Up]/[Page Down]?
I can also switch workspaces in the offline editor with [Tab] [Next]/[Last] when its shortcut on a desk is [Tab] [Page Up]/[Page Down]. Not sure if its the offline editor, the keyboard layout on my Mac, or something else, but it has confused me before.
interesting! FaderPage UpArrow/DownArrow writes to the small red command line, but doesn't actually do anything...
I figured it out! This is how you change the fader page displayed in the PSD ribbon.
...and apparently, that's it? Disappointed that you can't assign fader pages to a fader wing with this command.
it's what [FaderPage] and [Shift]&[FaderPage] does, isn't it? yes, it's unsolved on @5 because of half fader pages. but i think johannes' syntax does make sense
