Template for Fine Art 700 ?
Hi Guys,
I have a customer in Berlin that needs a template for
Manufacturer: Fine Art
1. Fixture: 700 Spot
2. Fixture: 700 Wash
Currently using Martin Mac 2000 Wash and Mac 700 Profile extended templates, but not all of
the features are working. Tried making a template based on the values in the manual but
the values aren't correct in the manual.
Does anyone have this template? Thanks!
  • I had a chat with the Fine Art distributer, and apparently the Fine Art Spot 700 has identical DMX attributes to the Martin Mac 700 Profile - just set it to the same mode (Basic/Extended).
    The Wash 700 is a little bit different though.
  • Fine Art have now sent me an attribute list for the Fine 700 Wash and Fine 2000 Wash.
    Apparently the printed manual doesn't include all the details.
    1. Shutter (Home: 30 for shutter open)
    2. Dimmer
    3. Cyan
    4. Magenta
    5. Yellow
    6. CTC
    7. Colour 1
    8. Colour 2
    9. Zoom
    10. CMY Macro
    11. CMY Rainbow
    12. Fan Speed (best not implemented if possible as it can cause the fixture to overheat)
    13. Electronic Dimmer (again not worth implementing)
    14. Pan Tilt Macro
    15. Pan Tilt Macro Speed
    16. Pan (Home: 128)
    17. Pan Fine
    18. Tilt (Home: 128)
    19. Tilt Fine
    20. Pan/Tilt Speed
    21. Effect Speed
    I don't know what he meant by not implementing Fan Speed or Electronic Dimmer - I think you'll need to try out 0,128 and 255 for each to find sensible values.
    I'm not sure where the speed attributes should home either.
    (Update)
    Attributes 10 thru 15 should be at 0 for normal use, and Pan/Tilt Effect speed attributes at 0 for 'tracking'
    [edited by: Richard at 12:56 PM (GMT -6) on Sat, Mar 7 2009]
