Feature Request: FX Sub Tap Tempo Bump/MS Button
Hello,
I have a feature request that I think would make Eos a whole ton easier to busk on. As it stands, to set tap tempo for an effect, you have to [Learn][Time][Enter] before you can actually enter the tempo. This can be sped up with macros, but I think it would be a much easier solution to have bump buttons on FX subs act as dedicated tap tempo buttons, that way you can have one for each important effect, and you can even use the LED to show the tempo before you pull the effect live. A way to do this on a magic sheet would be a welcome addition as well. Thoughts? I come from the live busking event world more so than the cue'd out theater world, so this would make a huge difference in my workflow.
