Hello, I am relatively new to EOS and just ran into an issue with running multiple effects sequentially. In cue 1 I am running a simple intensity chase on channels 1-10 with a step-based effect. In the following cue, I am running a different intensity chase on the same channels with another step-based effect. I would like it so that the second cue stops the first effect and starts over with the second effect. However, even with asserting the second cue, the first effect continues to run as the second effect gradually overtakes it.
How should I go about resolving this?
Thank you,
Jackson
