Recalling presets with intensity links
According to the manual P238, Recalling Presets:
[Channel List] [Preset] [7] [Enter] [At] [/] [5] [Enter] - recalls preset 7 for selected channels.
Intensity values will be recalled at 50% of their recorded state. The intensity link is
maintained. If the intensity change is desired the user either needs to update the preset to
maintain the change and the link. Storing the data to another record target would break
the link and make the data absolute.
When I do this, no link to the preset exists.  I update the preset and the value doesn't change like it says. It stores the correct value, but not linked to the preset.
The syntax:
[1] [Recall From] [Preset] [1] [At] [5] [0] [Enter] - recalls the intensity of channel 1 from
preset 1 at 50% of the stored value. If channel 1 was set to 50 in preset 1, it’s recalled
value would be 25.
also fails to create a link to the preset.  Furthermore, it does not work for values above / 100.  (The other one above does work for values over / 100.)
What am I doing wrong?
