I would like a way to fade a effect to stop live. Now I van only snap them or do it with rate and size masters.
Johannes
Johannes
Here's a macro that could make that happen. Replacing "Sub 1" with a number of your choosing to build a temporary submaster for the purposes of immediately homing it in a time that you specify. Works with all effects currently running, and you get to keep them on a fader to roll them back up when you're done, if you want, but it looks like this only works as an effect master; assigning the fader to rate or size doesn't change the behavior of the submaster after executing this macro.
I suppose for cleanliness' sake, you could replace the Clear_Cmd Select_Last Sneak 0 Enter with a Group Sub 1 Sneak 0 Enter...
