So I use multiple cue lists, for example I may have:
Cue List 1 - Main LX
Cue List 2 - Video
Cue List 3 - Signer
etc.
These are set so that Cue list 1 executes 2 and 3 however If i jump ahead such as during tech or if I come out of sequence for whatever reason, I have to manually figure out which cue each stack should be in. For example I may have the following cues:
| List 1 | List 2 | List 3 |
| Cue 1 | Cue 1 | Cue 1 |
| Cue 2 | Cue 2 | |
| Cue 3 | Cue 3 | |
| Cue 4 | ||
| Cue 5 | ||
| Cue 6 | ||
| Cue 7 | Cue 7 |
Using the example above, If I was in Cue 1, and wanted to jump to cue 5, I'd then need to also do:
Go To Cue 2/3
Go To Cue 3/2
Otherwise Video and the Signer would be out of sequence. It would be great if we could have a setting that gives us true tracking so when I Jump to cue 5, the other tracking lists automatically jump to the correct cue in there own stack so that I don't need to jump through and find what cue each should be in.
