Wish list
A few things, I wouldn't mind seeing sometime in the future.
1. We need to see if a channel is running an effect in Blind/Active, nothing shows up now unless you select the channel.  This adds much time that can be better used elsewhere.
2.  I would love to have a snapshot for my Live monitors, and have a seperate one for my Blind monitors, as I run different setups in both views.
Any thoughts???
  • Ryan, it is possible I'm misunderstanding your question.  Running effects ARE displayed in the channel views.  In the summary view, the effect takes priority over all other data.  In the table view, both the current value and the effect are display per channel/per parameter.  The same is true in blind.
    Additionally, you can open the effect status display in live and/or blind.  This gives you a list of all running effects and the channels associated with them.   So, I'm not clear on what data you are missing??
    Snapshots don't include your live or blind state.  We do this pretty deliberately, since it allows you to build snapshots that change your display modes and flexi-states, but don't automatically switch you from live to blind.  But you can build your snapshots and recall them when you are in either live or blind.  Does that help?
    a
    [edited by: Anne Valentino at 10:18 PM (GMT -6) on Fri, Mar 13 2009]
  • I see, you did answer the question.\
    But I would like to be in Blind /Active Channels and see if an effect is running.  As thats 1 of the most common views I use in blind, just thought maybe you guys can put it on the list.  Right in Q340.1 ch 171+172 are running Effect but I don't see that in Blind/Active Chs unless I select the chs.  If I change My flexi to any of the above you described I do See that those chs are running that Effect, But I want to see that in Blind/Active, as far as I know running an effect means the ch is active, kinda like the green 0"s
    just my thought
  • Ah, the flexichannel issue.  Yes, that's been addressed in 1.5.  And even tracked effects are displayed in flexi/active.  :-)
    Thanks!!
    a
  • Sweet, can't wait. Hopefully it will be out by the time we are ready to upgrade at the end of April:-)
