The "Query Mark/Marking" Command does not work with Automark enabled. If Automark is disabled it works like discribed in the manual. But i like to use it with Automark enabled.
Am i doing something wrong?
Thank you for this report. You are not doing anything wrong- but it doesn't work. This is being tracked as Eos-50320.
Thank You for your Reply.
