Can someone explain to me how to use or why you would use "Phantom" in cuelist properties on the EOS system software?
Mike Starobin
Mike Starobin
Normally if you have the PSD unlocked latest played cue list will put it self there, and take over the command line (So if you play cue 1 cuelist 2 it will say 2/1 in the command line)
Setting a List in Phantom mode will disable this. A bit like running a macro in background mode.
It sounds like I could use it keep a cuelist list on a "sub Fader" , not the "Master Fader".
Make a cuelist "Phantom" means it won't appear on the Master Fader go button.(PSD)
