Whenever I play a cue, it plays. All is well. When I stop or go back, and then play a cue, it goes back again I’m on a MacBook Pro running 10.15.2 running Nomad 2.9.1 Build 17 with fixture library version 2.9.0.45
Could you check fader config and verify the button configuration for the fader you're playing those cues from?
Hi jeremyburd2002 we have discovered this is a Mac specific issue and have written this up.
As a workaround, you can use ctrl+space for Stop/Back. This bug is when using ctrl+cmd+space specifically.
