ciao a tutti
come posso modificare la schermata LIVE TABLE in modo da visualizzare in un monitor solo i motorizzati e in un altro monitor solo i canali dimmer e che quindi non cambi la schermata ogni volta che digito un calale?
grazie
ciao a tutti
grazie
There is no great way to do this. but one thing that has helped me is to have two different Live displays on screen. One featuring the flexi state Patched Channels and the other displaying the flexi state Selected Channels. It really helps cut through the clutter.
Like Wuz314159 said, there isn't a native way to do this.
However, the "View Channels" flexi state would be a good workaround as well.
You may select specific channels to appear in another flexichannel state called “View Channels”. This state does not exist until you select channels to view. After view channels is activated, it will appear in the rotation of flexichannel states when [Flexi] is pressed.
To select channels to view:
The channels you selected will be visible in this flexi state until you select other channels and press {View Chans} again. At any time, you can access the last channels you defined for this state by pressing [Flexi] until this state is visible.
To redefine the selected channels in the state, simply follow the steps above again.
