simple macro help
I wrote a couple of simple macros for Sneak Time 0 Enter and Sneak Time 2 Enter etc.
I'm having problems with macros for Offset Odd or Offset Even Offset Mirror in etc.
In live, I would typically type [Chan] 201 thru 220 Offset Odd CP 5 enter.
Macro with Offset Odd, Offset Odd Enter, Offset Odd Enter Close Enter all fail (I think because the CP command is after the selection)
some guidance please.
and, foreground, background, or blank?
Andrew
(stuck at home on a laptop.....)
  • Are you sure you recorded just Offset Odd in the macro without any thing else.
    I just tried entering
    group 1 learn 100 enter offset odd learn which recorded just
    Offset Odd in macro 100 and then I can do
    group 2 macro 100 enter CP 1 enter  and is works as expected
    One thing generally is to avoid puting enters in macros  as then they can be used more generally so if you leave the enter of your sneak macros you can do things like   Group 1 macro 1 CP 1   where macro 1 is just sneak 5 to do the 5 second transition to CP 1.
    If you then put these as buttons on magic sheets it makes busking easy
  • Thanks Mike.  that was it (the extra enters).  I had also a close command in there to close the CIA which opens with the Offset SK.  it's an issue on the laptop but not on the console with 2 monitors.  I've taken the close out for now.  Of course we'll have to see what it looks like back on the full size monitors with a custom DS set-up (I think that may be easier than a magic sheet).
    Andrew
