DHA effects wheel as a fixture?
Hi!
I am running a DHA effects wheel (a simple two motor system where when the two motors are =, the wheel stops, when one channel is higher rotates forward, when the other is higher rotates reverse, and I was wondering if anyone can suggest a fixture in the ION that would make this work...Currently I am running them as dimmers which works fine, but I wondered if there was something already in the library that would work for this as well.
Thanks.
