Going through Level 3 EOS on LearningStage and got to Filter and Make Null and hosed the show file. (The course on LearningState is still 2.5 (for whatever reason), but I'm running 2.9.1 Build 17 on Windows.)
- In LIVE
- no little 'N' anywhere to be found.
- I can change the intensity manually
- Go to Cue 0/Out & Sneak don't reset anything
- In BLIND
- No 'Filters On' anywhere in CIA
- Every parameter has the 'N', EXCEPT a few 'Mark/MK's
- If I, "Cue 1 Thru Enter, 1 Thru 999 Make Null Enter", nothing changes. If I do it a second time, the 'MK's go away and also get the 'N'. A 3rd time does return it the 'MK's
- Must not have noticed before, but in retrying everything to write it down, I have been able to UN-'Mark Null' all non-Intensity parameters. Just wasn't scrolled over to Fixtures with non-Intensity to have seen it.
- If I, "1 {Make Null} Enter", OR "1 {Intens} {Make Null} Enter", OR "Group 1..." any number of times it still won't un-'Mark Null' on Intensity
- I've looked at the Palettes, since in Filters we messed with those, but I don't see anything in there to fix
