Hi All,
Bit of a minor conundrum while setting up automatic CPs for a busking file:
In live, channel 4001 Hue 0 Sat 100 enter
Live Table shows 100% sat, sat encoder shows 91.6017%
Select last record CP 901 by type enter
CP 901 now populates 91.6017% sat to encoder and 91.602% sat in Live Table
Go to Blind CP 901, select last Hue Sat recall from 4014 enter
4001 CP 901 enter, CP now populates 100% sat in Live Table but 91.6017% on encoder
So I guess my questions are:
- why the mismatch between encoder and live table?
- why does the live table change when I record that value to a CP?
- and why can I force the CP to 100 in blind when it won't let me record that way in Live?
Someone suggested that it was to maintain actual Hue/Sat values when copying to other fixtures that are capable of higher Sat but that logic doesn't track when copying to a fixture with a lower Sat capability at a given Hue value as it will also limit that data and the values won't match anyway.
4001 is an ETC D60 in Direct + Strobe
4014 is a Generic RGBCwWw LED
HSB is enabled in setup
EOS version 2.9.0 build 77
