Now that [At] [At] does the same thing as [Level] are there plans to change the Level key to something else? Maybe By Type?
Sorry if this has already been asked and answered. I swear I searched the forum for it.
There are currently no plans to change the Level key.
I would love if [Level] and [At] [At] could be set to different values, to have quick access to two different intensities.
You can change the value for [Level]
you find it in the user setup / manuell control
Thanks for your response. Sorry if I wasn't clear, I'm hoping for [Level] and [At] [At] to be different levels from each other. Say [At] [At] set to 50% and [Level] set to 25%. Right now Level feels a bit superfluous because it does the same thing as [At] [At]
So you're basically looking for four different intensities to be available via the facepanel, full, out, level and [at][at]?
