In Patch, if you select Channel 1, then scroll down to another Channel -maybe Channel 50- and you click at Channel 50 the List jumps automatic back to Channel 1.
You can reproduce this constant.
In Live the Channellist -in Tableview- do similar the same.
If the lowest Channel and the second Channel you wanne choose are possible in same view without scrolling -you can reach both without scrolling but you scroll- then the view jumps back.
If you wanne click at second Channel and you must scroll for reach the second Channel, the List will stay at second Channel.
In all other Blindlist the List also not jumps back to lowest. Doesn`t matter if you stay in Spreadsheet or not.
Is it a bug in Patch?
All Selections do with mouse, not with Comand Line
EOS 2.9.1 Build 17
