How to edit the text field in Magic Sheets. Field 1 thru Field 6 when I select text 1 thru text 6
There should be Text1 to Text10...?
Those are the text fields from Patch>Database. So you do assign them to a Field in the Magic Sheet editor, but they will always pull the content from the patch.
