It would be very cool if you could drag your finger across a set of channels on the touch screen instead of tapping each one.
If I select from the screen and assign a value with the wheel the tombstone still has a highlight around it. So I have to deselect it before I work with any other channels. This is not the same behavior as if I type in the channel number and use the wheel.
