Hi all,
Just wondering if there's a way to add comments that will appear in the log? This would be quite useful when I'm testing some features out and can then review the log later.
Hi all,
You can't add comments, but pressing [Displays]+[Record] will add a "LOG_EVENT" flag to the logs
Thank you Jake. That will probably be enough.
A common trick I use is label a random/throwaway object in my show.
Cue 1 / 999 Label "Problem happens here" enter
That label gets preserved in the file, so you can do an easy text search.
