if i use EOS ver2.9 to pre program some Cues,, can I use it back on Console using previous EOS Ver like ver 2.6?
As long as you save as .esf (without the extra compression) you will be able to take the show file backward to older versions. Keep in mind that features that don't exist in that older version of code will not be opened with that show file when you open it (so if you were to go back to v2.0 you would not have fader config for example).
