I need to remove the blocks from a lot of cues. Is there a way I can select only cues with a block and then delete the block(s) on-mass?
There's no tool to select cues according to a condition. But if you want to get rid of all blocks you can select all the cues, Block Enter will block all cues, Block Enter will unblock all cues.
Worked a treat thanks. I was thinking operating [Block] would toggle blocks to unblocked and then the reverses - for ever! But EOS is smarter than that isn't it!
