ION Not "Releasing" Intensities After Go
I'm working on an ION, and when I'm running through a cue list and bring up some channels then press go (without recording), the channels keep "captured" (but I don't have capture mode enabled).  I'm not sure if a setting got changed somewhere or if I'm just missing something...  But when I press {Back/Stop} in the cue that I brought them up in they fade to their original cue data.  Any help would be greatly appriciated.
Shawn
  • Channels that are active (selected) on the command line re essentially captured.  You see yellow border around their tombstones, and if you were to press the [at] button with a terminated command line, those channel numbers get posted to the command line.  Press [clear] and they are no longer captured.  You can also make another selection (which captures a different set of channels) or perform a function that doesn't use a channel selection, like record.
    This is definitely a feature and works the same way on the Obsession.
    -Josh
