Use Eos to run Propresenter 6...
Here's my issue. I would like to use my Gio5 to run a propresenter file. It's just graphics that would need to change at the top of every song. Can someone point me in the right direction to find the answer?
Any help is greatly appreciated!
Jason
  • In propresenter you need to enable/purchase the communications module which adds artnet and probably sACN support
    You can then connect to the console with ethernet
    In EOS there is a fixture Propresentor which you can patch in the normal way  (from memory there was an off by 1 difference in propresentor universe numbering to eos)
    You then get parameters like Clip Select ,  Clip Trigger  and after a bit of playing with it you should be control it and just record in cues in the normal way.
    There was an error in the patch config a while back but it may be fixed where one of the parameters had a user range set as 1 - 100 whereas it was actually 1 - 255.  I think it was the clip trigger so if you asked for clip 2 you clip 4  as it was all multiplied by 2.55 if it still does that edit the use range on the parameter back to 255
