Full ML movement through submaster
Is there a possibility to get a full tilt movement of a moving light programmed to a submaster? I use the etc nomad on a Mac and Luminosus with an akai lpd8 midi controller. When I record the tilt movement on a sub and try to move it with a midi controller through Luminosus it would only move within the range from 0 to 135 or -135 to 0. So only half of the movement. Did I program the submaster the wrong way? Thanks for your help
