When you select all cue including parts in the list and placed to add any follow time.
Result is all cue parts are corrupting and added a follow timing for every single part.
v3.0
v3.0
Hi aki,
Would you please send us your showfile and logs? We have tried reproducing it here and are not seeing the issue as you describe. Feel free to upload it here.
Have you type to [Cue] [0.5] [Thru] [Thru] {Follow} [number] in The Hamilton Programing Project file.
You can reproduce same result.
this command works as expected. Parts can't have follow times and i don't think the command corrupts parts.
because you used Thru Thru the console will create all whole-numbered cues. this is the same behavior like when you want to use all channels, not just the channels in your flexi.
Thank you for answering the question.
It was my lack of understanding.
