Is it possible to export information such as Patch and Cues to a 2. something operating system and have a show originally created in 3.0 on an older board?
Hi Janet Rose,
You can use Save As in version 3.x to save the show file as either an .esf2 (Compatible with 2.9.x) or as a .esf (compatible with 2.x) but keep in mind any programming or features you've used that are not available in those earlier versions (XYZ Positioning, Effect Variables, etc.) will not be included and your show may not play back as intended.
Be sure to check any show file saved in this manner before relying on it for a live performance.
Thanks so much! Now, if we could just do a real show in the real theatre.
