Does somebody have a personality file for the infinity furion s601 (57 ch) by any chance?
If someone could share the file that would be great :D
the 3.0 library and probably 2.9.1 library updates have a fixture called Infinity S601 Profile with 57 channels. maybe that's the same?
if not you should post a link to the full manual, so the ETC tech people can submit a regular fixture request.
The Home position for the framing shutters is incorrect (all shutters about 50 percent in) and there is odd behaviour when moving frames. The fixture profile needs a look at.
Which EOS version are you using?
Which Lib version are you using?
Did you make sure that No Home Preset is interfering?
Did you find that this issue was corrected? Please let us know if you still need assistance, thank you.
