Is adding a bank of direct selects suppose to undo all the layout settings you already set in the above banks and snap back to 5x10 or 5x20?
In the attached video you can see what I mean, but let me give you a use case where this is annoying, so say you have your DS tab all set up the way you like it and all of a sudden you realize you didn't add the bank of effects you needed 30 seconds before you need it, then you added it and everything you had exposed above disappears as the banks shrink.
Tested on macOS and Ion Classic, both running 3.0.0.389 and also tested on 2.9.17 on both platforms, same behavior.
Tyler
