Help with setting up Movers
A couple of days ago someone gave me some good help to correctly set up the pan and tilt features in a profile. Someway, somehow I lost that information. My MLs pan 0-630 deg and this article was to help me set a straight forward beam as 0 or "Home". It involved pointing the fixture left, right and straight ahead and noting the raw DMX values and then with some math working out the correct min. max and home values for the profile. As the fixture will point forward on two occasions I'm not sure which value to look for. I'm trying to get my MLs behave so that they move left, right and up down sensibly. Any ideas as to what that article was (or any other advice on the subject) appreciated. Once I can control them sensibly in the XY display in the ML Panel and with my LIghthack Encoders I'd then move on to Augment3d. Want to end up pointing to an actor and then dragging the beam across stage as they move.
