Macro Trigger Mirrors & Interleaves
Hi all,
MA moving over to ETC.
I'm trying to setup Macros so I can select a group and apply either mirror or interleaves, then apply an effect. But I'm having an issue with it reopening the offset window (The pops in EOS are quite irritating at times)
My current syntax is:
Offset Num_Groups 5 InterLeave "ENTER"
1. Select group
2. Select macro to offset to mirror in
3. Select Intensity Chase effect
4. Close the offset window that for some reason pops up as I trigger an effect???
Any hints on the correct syntax/better way to do these offsets?
Josh
