Hi Everyone,
I have a problem when I go into a pixel map layer, there is no content in library 0. I have tried using the pixel map installer but it did not work. Does anyone have any ideas on how to fix this?
-Campbell
Hi Everyone,
-Campbell
How did it not work?
If the installer ran, but you still don't see files make sure that the Media Archive path in the shell actually points to where the installer put the files.
Ah, thanks. I figured out it installed on my D disk instead of C.
I did find the cause of my problem, accidentally installed it to my D drive instead of C
Tone mapping is not working on a single image pixel layer but is working on the background layer. The default panel on the left does not show any images
can someone help
