Event List 1
Event 1 Input MIDI: Note On: C5 (0x3C) @ 64 On Channel 1
Action: Sub 1 On
Sub 1 bumps on and off - I would expect this to only turn Sub 1 on, instead of toggling it as that's what the "Bump" action is for.
3.0 b389
Event List 1
Action: Sub 1 On
3.0 b389
if you give the Sub a Hold... is this helpfull?
No - the issue is that the sub is toggled on the trigger of Event 1, instead of turned on and remaining in the on state.
Hello Scott,
i quickly hocked up some testing at my place.
I made a Sub1 and a trigger with a Note C at 0 velocity.
triggering the note via my Keyboard.
even updated to 3.0 b389
it works fine for me.
Please have a look in Tab99, there you can check out the incoming midi Note.
you will have 2 incomes.
First: Start of the Note
Second: End of the note.
If you got 4 inputs, your note is doubled somewhere and than the "Bump FX" is explained.
So please have a look at Tab99.
And please keep on shareing. It's quite interesting : )
Hi Scott,
We took a look at this and have captured this for future development.
Thank you Seth.
