Hi all, recently picked up a Pulsar Chromabank 2. Can't get the patching to work on my Ion. Bits work if I patch it cell by cell but even then the chases don't run. Any one got one? Thanks.
Which fixture type from the library did you try, or did you write your own?
I wanted to use the desks fixture library so that I could use the pre programmed chases.
I've tried all of the Chromabank variations without much success. I can jiggle the patching to get them all to light, but no luck with the chases. I can leave it at that and just use the generic desk effects, but if the desk has the right fixture type I'd like to use it.
I don't know those fixtures, but you say you have Chromabank 2. The library doesn't seem to have version 2. If the patched fixture type doesn't match the real life fixture type, it's not surprising that stuff doesn't work or behaves differently.
You can request a fixture type be added to the console library by starting a new post in the Fixture Request subsection of this forum. You will have to attach library pdf or add a link where it can be downloaded
