Feature Request: Option to turn off per-channel-priority
I know, this is not an EOS problem, but EOS uses per-channel-priority packets with an alternating start code of 0xDD, but many software does ignore the start code and read this data as DMX data, which will cause flickering in the software.
I am not entirely sure, that EOS uses these packets for, because you can not specify a priority for a single fixture, so why not have the option to disable the per-channel-priority packets?
