EOS Wing faders jam
We have an Ion Xe with a split EOS Fader wing. What I've done is to create submasters for different scenes. Then I assigned those subs to faders. Finally, I created macros that adjust the subs at different sneak speeds, which also causes the faders to move by the internal motors. Anyway, things are all good, except I was teaching a coworker how to run the console via these macros that I created, BUT what I noticed is that sometimes a fader will stop in mid-fade. It is very intermittent, and I can't really see any consistency for why. Sometimes it will stop fading up. Sometimes it will stop fading down. It will also stop at any point during the fade. Once the fader gets jammed then the sub and all the channels of that sub stop adjusting. I'm assuming that this is a problem with the motors, but I thought I'd drop by here to see if anyone has experienced this or might have another reason for this. Thanks.
