Hello,
I have two moving lights that have the purpose of aisle lights, how would I control the position (tilt control) of them with a submaster/fader?
Hello,
if they're aisle lights then that sounds relevant for safety. i don't think they should move at all. did you make sure that both the power and their DMX will remain in case of emergency?
They're supposed to move anywhere around the stage, How would I add the pan and tilt settings to a fader?
of course you can add them to subs, but it feels like you're trying to imitate the behavior of encoders. i'd suggest sticking to encoders, subs will make it more complicated down the line because you can't use Update or RecordOnly
I work on an Element 2 and we only have faders, that's the reason why I'm trying to use them, it would just be for busking.
