So I've run into an odd thing: when I try to swap address from populated channel to unpatched channel, both just end up blank instead of swapping. I feel like this used to work before 3.0, does anyone know if this is a bug?
This is a bug and has been around since at least v2.3.0, but is on the list to be fixed. We apologize for the inconvenience. It is currently being tracked as Eos-30460.
The workaround is to give the second channel a type before swapping the address.
Thank you both for the helpful info!
