SMPTE ID 0 is a valid source ID on Response SMPTE GWs, but not in Eos.
It should probably be a valid ID in Eos.
SMPTE ID 0 is used to disable SMPTE Group output. This is visible in Concert (though not on the Widget itself at this time).
Something I learned while testing - SMPTE will continue to be sent via UDP if configured, even when SMPTE in RX ID is set to 0.
To stop UDP SMPTE being sent, set the Destination UDP Port to 0.
Interesting, thanks!
