Cue with manual action never ends
I tagged this onto the discussion in another post but perhaps no one read it.
I created a cue that has a S4/iCue fixture in it and set the Focus time to manual so I could use the playback fader to control the movement of the iCue mirror.  This worked OK but created a problem.  I also specified a Hang time on the cue so that when the manual move completed the next cue would run. BUT, even though all the other moves in the cue completed in their specified times (before the manual move completes), when the manual move completes the cue does not end and therefore the hang time does not cause the next cue to run.  The cue remains colored RED in the cue list display.  If the manual moves completes before the timed moves then the cue ends normally.
Is this a feature or a bug?  Running v1.4.3
  • We just took a look at this.  The fact that the cue stays "red" in the PSD after cue completion is a bug and will be placed on the list of things to fix.  We need to add the ability for a manual cue completion to trigger a hang.  Will also place on list!
    thanks much!
    a
  • Anne,
    If I understand your answer correctly, the Red display and the Hang function not being triggered are two separate issues and that fixing the Red status will not also cause the manual action to trigger a hang?
    That will be really confusing since at least with the way it is now, I had an idea why it didn't work - even if in the end I wasn't exactly correct.  If the status display turns yellow at the completion of the manual action and the hang doesn't get triggered one would really be confused.
