When looking at the about screen under the usage section with a preset selected, most of the data above the table says zeros when it should be giving values. Is this a known bug?
Num. cues that move, num. channels and num. cue lists all return the correct data.
but First cue move, Last cue move, Last cue track, Num. of cues moved, Total num. of cues used in, all return zeros when I know for a fact that they have data. The table below those shows Channels that use and Cues that move full of data.
Is this supposed to work another way or is it broken?
I’m on a Ti, eos 2.9.1
