when I set a change of image of a moving light between cues, the gobo just suddenly snap changes into another, I want the image to be slowly changed from the one to another
because Gobo_Select is a Snap parameter if will ignore the cue/category timing, but it will follow discrete timing on that parameter.
so how could i change the parameter of the gobo? or it could only allow to do snap
discrete timing means: (in Live) Chan 1 Gobo_Select Time 5 Enter, Update Enter
