Using an Absolute Burst Color Effect. While running the Effect live making a change to the Effect's Color Palette does not take. This is whether the Effect is being changed in the Blind Editor or Live in the CIA with the Edit Softkey. The Effect needs to be stopped and re-run. I am giving the Color Palette step a Dwell and Time of 0. Other Absolute versions change fine in Live, but that might be because they have a timing in the step. Even if I give a 0.01 Dwell time only half of the Channels change. Checking this on a GIO, Ion, and Nomad with Firmware 3.0.
