Change Target Status Bar column order
Is there a way to change the order of the columns in the Target Status Bar in the Live tab? I'd like to have it match my PSD, with the cue Label column between the cue number and timing info. My Tab 2 is set up as I would like it, but the Tab 1 Target Status bar doesn't match with it. See attached photos.
This is Eos 3.0.0 build 389 on a Windows 10 desktop, using two monitors. Resolution for the monitor containing Tab 1 is 1280x1024, and resolution for the monitor containing Tab 2 is 1366x768.
